LOG4OM - OMNIRIG - 7300
i have the log4om ,omnirig and 7300.It seems when i have set to work with jtdx the radio turns to rtty and fil2 .I open the jtdx or wsjt after the log4om without click on cat and the radio when syghronise with onmirig it turns to rrrty and filter 2 ,after some seconds or minute the contact is lost betwwen radio .This happens only with 7300 and not the ftdx10 i also have .Even the mneu tab ft8 that 7300 have and set it after it turns to rtty it unloads .THE log4om the cat interface tab switch to digital is default ft8 or not ,but always happen switch to rtty.I check all i reset the 7300 2 times and i can't find nothing for a solution .Without omnirig the 7300 have no problem with the wsjt or jtdx
Re: LOG4OM - OMNIRIG - 7300
Same questions to you ....
Which rev of V2 (see Help About). Which Version of Omnirig ? All Softwares running with administrative rights ?
log4om 2.29 ,omnirig 1.20 and No i don't give admin rights to run ,i do a simple install
Update the Omnirig radio files to the latest.... and then set the radio in omnirig to IC-7300-DATA
Mike
K2GC
K2GC
Uninstall the USB divers for the rig in the PC and install the GENUINE Icom ones without rig connected as instructed by Icom
Then ensure that you select OMNIRIG in the JT program NOT your radio
I had a fresh install of everything on my laptop i use for POTA. I had this exact problem where every time I used Omnirig from WSJT, it would set it to RTTY. The other day I discovered (after updating the radio definition files in omnirig, so I cant tell you if it was there before or not) that there is an option that reads IC-7300-DATA. When I switched to that in Omnirig, WSJT operates properly using USB-D, and the world is happy now (since I can now call out to the world via FT8 properly!!!)G4POP wrote: 13 Mar 2024, 08:20 Uninstall the USB divers for the rig in the PC and install the GENUINE Icom ones without rig connected as instructed by Icom
Mike
K2GC
K2GC
