Dear colleagues
I have made several QSOs with YB7 stations on Borneo (Balikpapan for instance). YB7 Borneo is OC-088 according to IOTA directory. For 9M6 or V8 stations, I can select OC-088 in the IOTA groups list. For YB7 I don't find it. For information I am still using LOG4OM V1 release 1.45.00
Can you help me please? Thank you in advance and best 73
Peter HB9FMN
IOTA Number for Borneo YB7 missing
Re: IOTA Number for Borneo YB7 missing
Firstly check out the IOTA Ociana islands and you will find the OC-088 listing is for East Malaysia/Brunei/Indonesia, which if you select East Malasia as the country in Log4OM will provide the required IOTA ref.
However as a general rule when you cant find an IOTA reference use the steps below
1. Update the IOTA file ( Settings/update resources)?
2. If you have the latest IOTA file and its still not listed, speak to IOTA because they supply the download file, not us!
3. If all else fails add the unlisted reference manually - Instructions in our user guide butas a hint click black plus sign (+) to add an 'Unlisted reference'
Thank you for your support Terry. I will proceed according to your instructions.
73 Peter HB9FMN
73 Peter HB9FMN
