Cluster double click doesn't work
Posted: 15 Nov 2023, 11:48
Good morning,
I'm still struggling to get the CAT working properly. Up to now, mostly, I can't double click on a cluster, the cluster window closes before the second click. The selected callsign appears then in the Log4OM window, but the band and the frequency of the transceiver don't change. Exceptionally, the double click has sometimes worked correctly.
I use Log4OM version 29.9.0.0 running on a PC with Windows 10 64 bits professional, 22H2 version. But I had already the same problem with the fist Log4OM I installed in November 2022 (version 2.24.0.0). My rig is an Elecraft K3 with a KPA500 amplifier. My connection is an Elecraft USB to RS232 adapter cable with a FTDI chip. I use Omnirig with the parameters mentionned in the attached PDF file.
This system works correctly with Logger32 which I have been using for 15 years.
Thank you for your help and 73
F4FNT
F4FNT
