LOG4OM Freezes due to Cluster Issues
Posted: 18 Nov 2023, 00:49
by kb3z
I have noticed that there are times when LOG4OM will freeze when there is an issue with the Cluster that I am using. I normally use W3LPL as my cluster. I do not send the spots from LOG4OM to my SmartSDR Screen. So I know that is not the problem. But I guess if the cluster for some reason shuts down the Program seems to freeze. If I X out the Cluster Screen it seems that things go back to normal. I then restart the cluster and it will send spots to the LOG4OM Bandmap. Is there a reason why this is happening? When I use N1MM and the cluster goes down, the whole program does not freeze. But for some reason it occurs with LOG4OM.
Mark Griffin, KB3Z
Re: LOG4OM Freezes due to Cluster Issues
Posted: 02 Dec 2023, 10:36
What Log4OM version are you using - Help/about info - Please dont say the latest version!
What Windows version are you using?
Have you tried a different cluster server?
Are you using a detached cluster window or what exact window are you refering to?
