Flex 6500 with Omnirig V1
Posted: 02 Dec 2023, 16:53
by F6EXV
Hi all
I have been following 2 youtube videos on how to set up L4OM with Omnirig... and of course it does not work...
As soon as I launch L4OM, it switches my 6500 to TX, (without any power out, just TX), and whether I click on start CAT or stop CAT, it will never connect....
Any idea what I should look at please ?
Paul F6EXV
Re: Flex 6500 with Omnirig V1
Posted: 04 Dec 2023, 13:24
I have a friend, KG8V who had a problem caused by a win 11 update where is removed his 'SmartCAT' com port, we fixed it as follows.....................
Check in Smart Cat and make sure that you have both a com port connection (it will probably have a name that you allocated) and also a Winkeyer connection, if not then add them.
Then check that Omnirig is using the CAT com port for SmartCAT and that Log4OM Winkeyer is using the correct winkeyer com port allocated by SmartCAT
