Yes..things have changed....the below changes to 60M that I created are in sync with the somewhat recent updates to the 60M band plan.
https://www.arrl.org/band-plan
60 Meters (5 MHz channels)
*Only one signal at a time is permitted on any channel
*Maximum effective radiated output is 100 W PEP
5330.5 USB phone1 and CW/RTTY/data2
5346.5 USB phone1 and CW/RTTY/data2
5357.0 USB phone1 and CW/RTTY/data2
5371.5 USB phone1 and CW/RTTY/data2
5403.5 USB phone1 and CW/RTTY/data2
1. USB is limited to 2.8 kHz
2. CW and digital emissions must be centered 1.5 kHz above the channel frequencies indicated in the above chart
So here's an update to match the above
<BandPlanRange>
<Band>60m</Band>
<Start>5330.5</Start>
<End>5533.3</End>
<EmissionType>DIGITAL</EmissionType>
</BandPlanRange>
<BandPlanRange>
<Band>60m</Band>
<Start>5346.5</Start>
<End>5349.3</End>
</BandPlanRange>
<BandPlanRange>
<Band>60m</Band>
<Start>5357.0</Start>
<End>5359.8</End>
</BandPlanRange>
<BandPlanRange>
<Band>60m</Band>
<Start>5371.5</Start>
<End>5374.3</End>
</BandPlanRange>
<BandPlanRange>
<Band>60m</Band>
<Start>5403.5</Start>
<End>5406.3</End>
</BandPlanRange>
<BandPlanRange>
<Band>60m</Band>
<Start>5331.9</Start>
<End>5533.1</End>
<EmissionType>CW</EmissionType>
</BandPlanRange>
<BandPlanRange>
<Band>60m</Band>
<Start>5347.9</Start>
<End>5348.1</End>
</BandPlanRange>
<BandPlanRange>
<Band>60m</Band>
<Start>5358.4</Start>
<End>5358.6</End>
</BandPlanRange>
<BandPlanRange>
<Band>60m</Band>
<Start>5372.9</Start>
<End>5373.1</End>
</BandPlanRange>
<BandPlanRange>
<Band>60m</Band>
<Start>5404.9</Start>
<End>5405.1</End>
</BandPlanRange>
