I issue eQSL for all QSOs.
However, looking at LOG4OM's QSO logbook, "eQSL sent" are listed as no.
I want to change it to Yes all at once.
DS1SKU
LOTW sent
Re: LOTW sent
Won-yong,
Use QSL Manager and select the 'Enable Update' option.
You can then adjust the values of the sent QSLs that you select to change.
Be sure you do a backup of your log before you make the bulk update ... just in case.
