New computer, new problem
AB7R
Post by AB7R »
I have a new windows 11 computer and using the current version of Log4om V2. I installed TQSL and update the services and confirmations sections in settings. But nothing is going to LOTW. Either auto or when uploading manually.
INFO: ADIF File created successfully.
INFO: TQSL Version 2.7.1
ADIF file not found on path: C:\Program Files (x86)\TrustedQSL\LOTW_UPLOAD_20231212230124.adi
LOTW END
I do have a file name Log4OM_log_20231212224642 in my n1mm export files folder.
Am I missing a setting somewhere?
Thank you!
Greg - AB7R
Caldwell, ID
Re: New computer, new problem
Think you have the 'Temporary path' ,in Log4OM Program Config/External services/LOTW tab incorrect
Should be something like C:\Users\YOUR USER NAME\AppData\Roaming\Log4OM2\temp
AB7R
Post by AB7R »
That did the trick. Thanks Terry.
Greg - AB7R
Caldwell, ID
