Cluster time format
Posted: 04 Jan 2024, 18:27
by W1BKW
When the cluster tab is selected, underneath the grid is the Connected/Disconnected status and then the Last Update time. Mine is in 12hr format AM/PM, still in UTC time, but 12hr format. Is there a way to set it to 24hr format so that it matches most UTC clocks. I looked through all the settings and couldn't find anything for time format anywhere.
thanks, Brian
Re: Cluster time format
Posted: 04 Jan 2024, 21:04
by KI5IO
W1BKW wrote: 04 Jan 2024, 18:27 When the cluster tab is selected, underneath the grid is the Connected/Disconnected status and then the Last Update time. Mine is in 12hr format AM/PM, still in UTC time, but 12hr format. Is there a way to set it to 24hr format so that it matches most UTC clocks. I looked through all the settings and couldn't find anything for time format anywhere.
thanks, Brian
Brian,
Try changing the time display options you have in your Windows O/S.
Posted: 04 Jan 2024, 21:54
by W1BKW
That worked! Not what I wanted (only wanted the application time to format to 24hr) but not an issue.
Thanks, Brian
