Page 2 of 4
Re: LOTW upload Freezes
Posted: 03 Feb 2024, 08:15
by DL4DBM
I'm not quite sure if this could help.... I had this same problem but it started with me as soon as I'd changed some ALREADY uploaded QSO's to LOTW from "YES" to "NO". I made some nice contacts in the past to whom I already sent a confirmation through LOTW but never got a confirmation back... So I changed these contacts from "YES" to "NO" hoping by sending my confirmation again, these stations would reply but here the problem with freezing started. As soon as I changed these QSO back to "YES" again, the problem disappeared. Somehow it's not possible to send the confirmation through LOTW again.
Have a great weekend!
Ben (DL4DBM)
Posted: 03 Feb 2024, 17:24
by WR0H
If you upload an ADIF directly via TQSL, it allows you to override the "one upload per qso" limitation.
Now I find myself in the strange situation of my log showing that I have received LOTW confirmations without sending one--obviously not the case. QSO Manager does not allow bulk editing of LOTW fields, so I'm stumped as to how to update the qsos, other than one at a time.
Posted: 03 Feb 2024, 18:46
by KI5IO
WR0H wrote: ↑03 Feb 2024, 17:24
Shawn,
If you utilize "QSL Manager" you can adjust the Sent & Received values.
Adjustments can be made one QSO at or a time or in a 'bulk' mode.
"QSL Manager" is NOT the "QSO Manager".
Give it a look, check out the User Guide and/or also watch the videos that Terry has created.
Posted: 28 Feb 2024, 12:13
by IW3GCR
Hi everyone, I too have the same problem.
QSOs are not automatically uploaded to Lotw, but I have to use the method with the TQSL program or manually, one QSO at a time.
Windows10 system and Log4Om version 2.31
Thank you
Nicola IW3GCR
Posted: 28 Feb 2024, 12:21
IW3GCR wrote: ↑28 Feb 2024, 12:13
Thank you
Nicola IW3GCR
What TQSL version number are you using?
Posted: 28 Feb 2024, 13:28
by IW3GCR
Hi Terry
Tqsl v. 2.72
Nicola IW3GCR
Posted: 28 Feb 2024, 13:55
by OA9DVK
It seems it is not just me then...
INFO: ADIF File created successfully.
INFO: TQSL Version 2.7.2
No private TQSL Password set
Executing TQSL with upload
MANAGED MODE SET
No matter what I do, there is no chance to have my qso uploaded.
Any clues?
Posted: 28 Feb 2024, 15:19
by IW3GCR
I can't find one: manually the upload works, automatically it doesn't.
Nicola IW3GCR
Posted: 28 Feb 2024, 18:07
Manually from Log4om?
Posted: 29 Feb 2024, 08:42
by IW3GCR
IW3GCR wrote: ↑28 Feb 2024, 15:19
Nicola IW3GCR
Manually is working fine !
Nicola IW3GCR
