software updating change
ve3wej
Post by ve3wej »
is it possible to create an update version, so that changes I have made dont go back to prior to hours of work
I removed about 75% ( guess) of the awards, to only show in the drop list what I may use, only to find they are back
version updated to 2.31.0.0
Re: software updating change
ve3wej wrote: 02 Feb 2024, 00:46 is it possible to create an update version, so that changes I have made dont go back to prior to hours of work
Dave,
Where are you removing the awards? I use Settings / Configuration / User Preferences / Award Preferences
It is a simple drag/drop between the Active & Inactive Panels.
Certainly not "hours". :?
ve3wej
Post by ve3wej »
the point was that I had already done it, and not likely to do it again, if the next update replaces it again
