I have downloaded the usb driver v6.7.6
I have configured the baud rate on HAMLIB, Windows driver system and the FT991A to match
The CAT does not latch when activated
It used to function perfectly then the following problems appeared:
1) the CAT connection would stop working when LOG4OM was running
2) the program would latch the TX function on the radio and I could only stop transmitting once I had unplugged the usb cable
I am attaching the zip file.
Many thanks. I would really like to get this program functioning as it should as it is a really nice logging program
Yaesu ft991a CAT/HAMLIB connection problems
Re: Yaesu ft991a CAT/HAMLIB connection problems
PLEASE DO NOT POST SUPPORT REQUESTS ON THE FORUM THEY CONTAIN YOUR PRIVATE INFORMATION LIKE PASSWORDS>
I HAVE DELETED THE FILE FOR YOU
Where must I post it then? This is so confusing
You only send support requests by email to the team member that requested it
Your issue is something local to your set up have you searched the forums to see if this has happened to someone else?
Just chatting to a 991 owner and he uses Omnirig in Log4om without issue
I finally resolved the issue. I had to reload Log4OM and then the issue cleared itself. There must have been a problem with the first download that I did.
