Using Multiple Monitors - constant issues
NY4Q
Post by NY4Q »
I use three monitors and Log4OM constantly loses the clock and the editor window (meaning I double-click a recent contact to edit) well it launches so far off the screen I can move it or it isn't visible at all.
Is there a way to reset the program to bring all those windows back to one monitor or in close proximity of the main window?
Re: Using Multiple Monitors - constant issues
NY4Q wrote: 23 Mar 2024, 21:27 I use three monitors and Log4OM constantly loses the clock and the editor window (meaning I double-click a recent contact to edit) well it launches so far off the screen I can move it or it isn't visible at all.
William,
Go to: Settings / Configuration / Edit Program Config ...
You will see a button on the upper-middle-right that is labeled "Reset Window Positions"
Tap that button, then tap "Save and Apply" and then restart Log4OM.
That "should" resolve your situation.
NY4Q
Post by NY4Q »
I keep forgetting to come back to thank you for that tip Nolan, until today that is. ha
I 'thought' I had combed over every menu too.
Phil (NY4Q)
