.csv export save selection options
do1otw
Post by do1otw »
It would be great if you had the option to permanently save the selected options from the csv export window. The same applies to shifting the order, which should also be able to be saved.
Currently I have to re-click the checkboxes in the selection fields and change the order manually every time the csv export window is closed.
An example in the picture
4z1tl
Re: .csv export save selection options
Post by 4z1tl »
Agree and same for the ADIF export
Already on our list
