I'm new to Log4om and new to the forums, so I hope this is the correct place to ask this question.
I have a Windows 11 system with the Yaesu USB driver installed in it. It produces an "enhanced com port" and "standard com port". Can I use one of these ports with LOG4OM2 as the CAT port instead of the serial port on my radio?
My radio is a Yaesu FTDX101MP.
many Thanks, Phil NC3S
Using CAT with Yaesu FTDX101MP and the USB driver
Re: Using CAT with Yaesu FTDX101MP and the USB driver
Yes as far as I know you can, follow the instructions for Omnirig
Thank you,
It worked! It uses the "enhanced port" and I had to change the Omnirig setting to 38400 bps.
