Lotw Automatic upload ?
Posted: 07 Apr 2024, 20:13
by TA4AU
Log4om not upload my qso automatic lotw , it was made, but it dont do it
Automatic upload on application close option is check it .
Re: Lotw Automatic upload ?
Posted: 08 Apr 2024, 00:20
by DF5WW
LotW certificate expired?
Posted: 08 Apr 2024, 21:02
by TA4AU
Valid until 2026
I can make manual upload but not when closed application no upload autamatic
Posted: 08 Apr 2024, 23:26
by KI5IO
Mehmet,
Couple questions:
What version of Log4OM are you using? Don't tell us "latest" ... Go to "Help/About" so you can provide the actual version number.
What is the input method of the QSOs you cannot upload via the "auto upload" feature? Are they input from the FTxx APPs (such as WSJTx, JTAlert, Gridtracker ?). Is that input via a UPD Inbound port?
That will help provide us some more information so we can better help 'debug' your situation.
Posted: 11 Apr 2024, 21:02
by TA4AU
I use 2.32.1.0
input methot is manuel all qso is SSB and cw no use 3. rd software.
Posted: 04 May 2024, 13:50
by WR0H
I'm curious as to the resolution of this as I have the same issue. LOTW manually uploads fine but does not automatically upload at the end of my session.
Using V2 2.32.1.0 with WSJTX & JTalert with UDP inbound connections.
