I recently moved to Log4om and pleased with the features.
The previous logging program Dxbase had QSL cards templates to choose from or the option to make you own with logos, flags and to add your own image. You could build for 1 or up to 4 QSO per card. It was able to print 4 per card stock sheets (8-1/2 x 11)
I would use Avery labels for addresses.
Could this be a future feature?
Cliff
K4HCP
QSL CARD templates
Re: QSL CARD templates
Cliff,
I came from DXBase also and that feature is already in Log4OM. In the manual for labels.
I am available if you have any questions.
Greg
WB2BIN
Greg
WB2BIN
I did see under Utilities>Label Definitions that multiple QSOs can be put on a label.
I have attached a QSL Card I created with logos and a image from old logging software. If a QSL Card Creator is available can some direct me .
Cliff
K4HCP
Cliff
K4HCP
PDF_20240420_0003.pdf
- (180.64 KiB) Downloaded 252 times
