Lost all my configuration
EI5KI
Post by EI5KI »
I turned on my logging pc this evening (after having used it earlier today) and Log4OM started up as if it were a new installation. It seems to have lost all the configuration information. I have reconnected it to the database successfully and I am working through everything else, CAT connection, cluster and so on. I've not yet got to the connections for QRZ.com and eQSL etc. Is there a way to find the original configuration? I don't know how it happened, of course. It was certainly a panicky moment, although I knew I had backups of the database.
F4INZ
Re: Lost all my configuration
Post by F4INZ »
I had a big scare with a similar issue.
Don't panic, take a look at the post https://forum.log4om.com/viewtopic.php?t=7411
Maybe you're in the same situation ?
Best 73,
Andre - F4INz
