CAT has stopped working for VFO A
K9AQ
Post by K9AQ »
I an running Log4OM v2.32.1.0 with Omnirig 1.2. When I start CAT VFO A displays "offline" while VFO B displays the correct frequency. I am using Omnirig with two rigs defined: Elecraft K3 and Thetis (PowerSDR). Omnirig and Log4OM are not working correctly with either rig.
Even though VFO A displays "offline", if I click on a cluster spot the rig goes to the correct frequency. Without VFO A's frequency I can't log the QSO correctly.
In the past this worked very well and then over time and some program updates, it would only work when I rebooted the PC. That no longer resolves the problem
I am running Log4OM as an administrator.
I see others who have had the same problem but I can't see any resolution.
Please help.
Don K9AQ
K9AQ
Re: CAT has stopped working for VFO A
Post by K9AQ »
I uninstalled Log4om and Omnirig and then reinstalled the software. I set both programs to run as "administrator". After rebooting the PC, Log4OM is correctly displaying VFO A and B.
Don K9AQ
