What is the best way to enable 60 meters for the IARU region 2 band plan? When I tune to 60m, Log4OM reports that I am out of band. After examining %APPDATA%\LogOM\bandplan_r2.xml, 60 meters is not defined. It is defined in region 1, but is not quite right for the US bandplan.
Should I edit the region 2 XML file and add a 60m definition?
60 meters & IARU Region 2 bandplan
Re: 60 meters & IARU Region 2 bandplan
Yes just open the file in Notepad and add/modify the data then just save, not save as
Make sure that you have a copy somewhere just in case the revised bandplan gets overwritten during subsequent installations.
