Resend QSO via UDP outbound
IK0TIX
Post by IK0TIX »
Good morning OM,
I'm doing the Marconi Award and I have log4om connected via UDP to the HamAward platform. All Log4OM QSOs are transferred.
Last night, probably due to a network problem, some QSOs did not pass through. Is it possible to select one or more QSOs from the "Recent QSOs" and resend them via outbound UDP?
Max IK0TIX
Re: Resend QSO via UDP outbound
No you need to export them as an ADIF and import into the other program
IK0TIX
Post by IK0TIX »
Many thanks Terry, I had imagined it, the problem is that HamAward does not allow the import of the ADIF by the user, I have to send the file to the administrator. I will Survive ;)
Max IK0TIX
iz7djs
Porta UDP per HaamAward
Post by iz7djs »
Buongiorno e buona domenica
Qualè la porta UDP che collega Log4Om a HAmAward ?
IU2RKO
Post by IU2RKO »
In SETUP/CONNECTIONS/ nella parte destra devi semplicemente mettere
N. di porta 12060
Nome a scelta tipo HAMAWARD
Attivare Flag Broadcast
e aggiungere con il + verde
Ci sarai già arrivato ma lo metto per altri.
