No label print on the Beta release
PD2TX
Post by PD2TX »
Hiya,
I noticed that in the newest beta-release: 2.32.1.6 the labelprint function wont work.
After i click the PDF function for printing, it wont genarate the actual print.
Step 3: Print
But at Step 4: QSO Update no selection showing up.
Downgraded to the stable version, and step 4 is working as it should be.
73, Nico
Pilots know why Birds Sing
Re: No label print on the Beta release
Confirmed. A shared library changed, updating components and checking
Issue found and fixed. Will be release in next public Beta. Thanks for reporting
iz8ewd
Post by iz8ewd »
I found what seems to be another bug in the label printing.
If in the label print routing process I add a manager in the QSL via field, it doesn't appear in the printed label. It only works if the manager was previously inserted in the edit QSO window.
Also, if in the QSO data, manager and shipping method was already specified, they are ignored in the routing of the label print menu.
iz8ewd
Re: No label print
Post by iz8ewd »
To clarify, my bug report is referred to the last stable release 2.34.00
KA1WPM
Post by KA1WPM »
I just tried to the print on the 2.35.0.0 version and had the same issue as described in the original post. The log file reports
2025-02-15 16:58:16.6344 INFO: [dje_z268CGSYC4JP929LXM5T77MGMQZAA_ejd] : [LABEL PRINT] Printing 20 labels
2025-02-15 16:58:16.6500 INFO: [dje_zE8NR3W96EB8SHZDC7Q56F_ejd] : [LABEL PRINT] Begin label printing process on C:\Users\Dana\AppData\Roaming\Log4OM2\temp\20250215165816.pdf
2025-02-15 16:58:16.6500 ERROR: [dje_zE8NR3W96EB8SHZDC7Q56F_ejd][MoveNext] : [EXCEPTION] Object reference not set to an instance of an object. System.NullReferenceException: Object reference not set to an instance of an object.
at L4ONG.OUTPUT.LabelPrintManagement.dje_zE8NR3W96EB8SHZDC7Q56F_ejd.MoveNext()
2025-02-15 16:58:16.6500 INFO: [dje_z268CGSYC4JP929LXM5T77MGMQZAA_ejd] : [LABEL PRINT] Nothing to print
Thanks and greetings to all!
-- Dana, KA1WPM
I have just tested label print and its working fine
Check your default PDF program, this may have changed due to a windows update
I gave up on Adobe some years agos and now use Foxit reader
KA1WPM
Post by KA1WPM »
Thanks for the tip. I put Foxit on the machine and set the pdf default to use it. Unfortunately the issue has persisted. Still, thanks for checking it out on your end. I will monkey with it a little more some time in the future. Cheers!
-- Dana, KA1WPM
KA1WPM
Post by KA1WPM »
I found my issue. My custom label definition has gotten corrupted. It's loaded with non-printing characters mixed in with the text.
Cheers
-- Dana, KA1WPM
