LoTW freezes
ik3umt
LoTW freezes
Post by ik3umt »
10 qsos are uploaded ok
20 or more upload freezes (I didn't try where the limit is , 11 rather than 19...)
I enabled log tracing but nothing seems involved.
Attached is a side by side log of failed and successful operation.
Of course the LOG4OM generated adif file (also one with 1000+ qso) is correctly loaded when using TQSL program manually.
Any suggestion ?
Re: LoTW freezes
LOTW has only just come back on line after a major intervention by hackers and there are reports of continuing issues so perhaps wait a week and try again?
DO9KW
Re: LoTW freezes
Post by DO9KW »
Also, the LotW team has implemented a new "feature" that should prevent users to upload duplicates:
We have also implemented a process to reject logs with excessive duplicates. Please do not upload your entire log to “ensure” your contacts are in LoTW as they will be rejected.
https://www.arrl.org/news/arrl-systems- ... disruption
Maybe this has something to do with it, I had the same issues.
Also the shutdown of Log4OM took a long time and the QSOs were not uploaded to LotW allthough I did not change anything in the settings but it seems that this works again now.
73s
Stefan
DO9KW
73 Stefan
ik3umt
Re: LoTW freezes
Post by ik3umt »
No problem to wait , but I think the problem resides on Log4om, it's a ten against twenty records making difference ? , and no LoTW errors back , it simply freezes.
Again , another 3K records adif uploaded with TQSL gives no issues.
ik3umt
Re: LoTW freezes
Post by ik3umt »
UP for this issue, same behavior, any idea ?
