Restarting cluster
K0AY
Restarting cluster
Post by K0AY »
If I loose my internet connection, naturally I stop receiving cluster information.
But when the internet resumes, the cluster does not resume updating. Is there a more
elegant way to get the cluster to continue updating other than restarting the program?
Art
K0AY
Re: Restarting cluster
Yes just go to utilities/cluster and restart the cluster.
We purposely don't keep trying to connect in the event of a lost connection because constant retries cause added CPU load.
K0AY
Post by K0AY »
That did it, many thanks as usual.
Art K0AY
Perhaps we can get Daniele to add a 'Re-Connect' button to the window that pops up to warn you of the lost connection at some time!
Mmmh there is a popup message (and it should works) to inform you that the cluster has been disconnected.
I need to make a check on that once again...
