My (F4)
Posted: 22 Jul 2024, 16:37
by HB9ETR
Hi...
Concerning SAT mode inputs.
I check the SATELITTE MODE box, the satellite appears, prop changes accordingly. I enter the elevation and bearing and lock both.
When I enter a callsign in the call info, the elevation and bearing revert to 0
Am I missing something?
Re: My (F4)
Posted: 26 Jul 2024, 07:48
Seems the lookup from info providers is over riding your input, for now enter az/el after the call is entered
Re: My (F4)
Posted: 26 Jul 2024, 07:56
the callsign lookup will "clean up" all data, but the lock button should work and keep values...
checking, thanks for reporting
Re: My (F4)
Posted: 04 Aug 2024, 16:16
by HB9ETR
Tnx for looking into this.
Linked to the same....
Having set the My (F4) for satellite work and then opening a NET.
The NET part works as expected until I save/close the NET.
Entries get transferred to the log but no indication of a satellite contact is transferred with it.
Is this another issue?
Re: My (F4)
Posted: 11 Aug 2024, 13:08
No, SAT and other details are not supported in a NET QSO, it's something we didn't expect could be useful, as usually a NET is ragchew on some local repeaters or with the usual group of contacts.
Please let us know what is your needs so we can eventually explore them.
Re: My (F4)
Posted: 20 Aug 2024, 10:26
by HB9ETR
Tnx again...i was just trying out the NET function when 3 of us were on air together in our group. All worked fine except the transfer to the mail log. I have noted there are a few nets on QO-100 which pop up from time to time with several participants.
I wouldn't want you to spend time on this as I am sure there are more pressing things to look at.
....the LOCK function, yes, the NET function, no.
