eQSL confirmations download
zl2aww
Post by zl2aww »
I ran the download confirmations utility that is part of the QSL manager but all I get is a text response in HTML text.
I ran the download confirmation a month ago and my confirmations was retuned slowly with delays between messages, which was the process I used. I have loaded the text response in NotePad and save it as a HTML file and open it via web browser. Apparently, one has to download the ADI file from eQSL which will have the QSO confirmations. But all I get is a web page with all the QSO’s listed as text.
What is the process now to get QSO confirmations. Log4OM manual still refers to the original methodology. Help will be appreciated.
Kind regards
Andre
See attached files
Re: eQSL confirmations download
OK standard request - What Log4OM version number are you using?
I just tested using the same date range you selected and all functioned as it should, so something is wrong at your end
zl2aww
Post by zl2aww »
Hi
Thanks for the reply. I'm running version 2.33.0.0.
I tried to running it today and first attempt it failed again.
Second attempt it started to download with the following message, and I used the "Last Download" option.
Downloading ADIF document from https://www.eqsl.cc/downloadedfiles/ALDA2223337.adi ...
Parsing ADIF file...
ADIF document parsed: 13 qso found.
The server must have been busy at the time I tried to download.
Regards
Andre
Andre,
I just downloaded 25 eqsl confirmations, including cards, without issue so its either an eqsl outage or perhaps sever slowness.
Could be your firewall or anti virus perhaps?
The fact that it downloads the file and parses it proves that your user details are correct
