Just curious as to how many cluster items are displayed when an OM has selected the "Show Cluster Grouped" option?
There is the item to select the 'Maximum Cluster Items', but that selection has a notation that it is ignored when the "Show Cluster Grouped" option is selected.
Thus the question: How does an OM know what that value is? What routine is used by Log4OM to chose whatever that value is? Does that value change over time or with the incoming spot flow from the Cluster feed?
As best I can determine "Show Cluster Grouped" selection does NOT impact the 'Maximum Band Map Items' or does it impact the Band Map display the same as the Cluster (F8) display?
If it does then should there not also be an information label for that item?
If it impacts one and not the other ... why would that be the case?
Just seeking to better understand.
Maximum Cluster Items?
Re: Maximum Cluster Items?
This will have to wait for Lele to answer on his return from Vacation as I dont know the answer
