Spotting on the Cluster
Posted: 11 Sep 2024, 19:51
by EI2GLB
Hi All
I have often ment to ask this, but why when I go to spot a station does Log4OM add all this gibberish to the comment field,
For example I wanted to spot 3D2USU and it pre populated the comment with this "CCC 3D2* DXCC 176 VUCC RH82 WAC OC WAZ 32 WITUZ 56 WPX 3D2 IOTA OC-016 "
I don't want to spot any of that nonsense, can it be disabled,
You can always tell people using Log4OM by the random cluster comments,
Trevor
EI2GLB
Re: Spotting on the Cluster
Posted: 11 Sep 2024, 22:46
Its award and grid data which is of possible interest to other paper chasers
No way to turn it off at this time but you can delete it from the spot before sending
Posted: 23 Sep 2024, 18:38
by EI2GLB
Thanks for the reply Terry, it's a bit over the top as only a small percentage of it will actually make it to the cluster,
But I don't spot that often so I can delete as needed,
Trevor
EI2GLB
