In the settings menu I configured the external services.
Under the LOTW tab I choose to upload all new qso's on application close.
When I activate this function when I close Log4om I get a message that the program is uploading to LOTW with a 120 sec time-out.
However every time I close log4om the program just hangs (a lot more than 120 sec) and I have to shut the program down killing the proces.
Any reason why this happens? Contacting LOTW through the QSL Manager works fine. I had to uncheck the upload on close.
73 Phil ON4VP
LOTW "auto upload on exit" hangs log4om
Re: LOTW "auto upload on exit" hangs log4om
Phil,
Has been mentioned a number of times. Various solutions work for different OMs.
Take a look at the search links in the URL below and see if one of them might help you out.
search.php?keywords=lotw+upload+hangs+up&fid%5B0%5D=31
