Log4OM v 2.33 Windows 11
When I open the contest setting window the frame is vertically too small and the lower portion is not visible.
Any help would be appreciated.
Contest Setting Window too small
Re: Contest Setting Window too small
Sounds like windows display setting not set to 100%
System/display/scale - MUST BE 100%
My monitor resolution is 1520 x 1440. The trouble is I cannot work with Windows set to 100%, it needs to be 125%.
All the other Log4om windows work perfectly at 125% so setting windows 11 to 100% is a workaround and not a fix.
