Spots on Cluster not Aging Out
Posted: 02 Nov 2024, 14:44
by AI4FH
Spots listed on my Cluster page are not "aging out" and disappearing after the 10 minutes that I have set on the cluster configuration page "Cluster max age (min)" - ?? - I must be doing something wrong - what? Spots on there stay sometimes for hours until I disconnect and reconnect the cluster - then it starts over again with the same behavior.
Wes AI4FH
Re: Spots on Cluster not Aging Out
Posted: 02 Nov 2024, 16:21
What version number of Log4OM are you using? see help/about
And what cluster server do you use?
Posted: 03 Nov 2024, 13:35
by AI4FH
Version 2.33.0.0
(PRI) AE5E (23)
(U) RBNTelegraphy (7000)
Posted: 03 Nov 2024, 17:34
AI4FH wrote: 03 Nov 2024, 13:35 Version 2.33.0.0
(PRI) AE5E (23)
I just set those servers on my test machine and after a few minutes having alllowed time for a couple of refreshes to allow the 10 minute timer to work it then just displayed 10 min old spots.
I will send you a download which has some extra logging info and ask you to install it then test again
Posted: 05 Nov 2024, 05:41
by AI4FH
Thanks. I installed the version that you sent and also removed the RBNTelegraphy - between the two actions the problem seems to have gone away. I wanted to add another cluster but could not get the provided list to display - is there any reason I need to have my machine acting as a server? I have that off for now.
Posted: 05 Nov 2024, 08:07
Not unless you want to send received spots to another program
