OPERATOR INFO NOT POPULATING AFTER LATEST DOWNLOAD
K2DJL
Post by K2DJL »
After downloading the latest version, operator/address, etc. info is not populating. All other info and interface with QRZ, LOTW is working ?
Re: OPERATOR INFO NOT POPULATING AFTER LATEST DOWNLOAD
Try a reinstall
K2DJL
Post by K2DJL »
OK. Just did a complete re-install and still no operator information. Everything else works. Thanks, Dan K2DJL
K2DJL wrote: 25 Nov 2024, 21:53 OK. Just did a complete re-install and still no operator information. Everything else works. Thanks, Dan K2DJL
Have you checked the Program config/info providers user name and password are working by clicking the test buttons on right
K2DJL
Post by K2DJL »
SUCCESS!!!
That was it. I must have made a PW change down the line.
Thanks Terry, you guys are the best!
Dan K2DJL. 73
K2DJL
Post by K2DJL »
Just made a donation. Thanks for all you do.
Dan K2DJL
K2DJL wrote: 26 Nov 2024, 02:09 SUCCESS!!!
Dan K2DJL. 73
:D :D
K2DJL
Post by K2DJL »
Hi Terry:
Having the same problem. Did re-install. Test showed "successful". Operator info still not populating when entering a call sign on LOG4OM. It shows the state or country but no operator info? Always appreciate your help. Dan K2DJL
K2DJL
Post by K2DJL »
QRZ API key is correct
Download of operator details from QRZ is nothing to do with the API key. The API key is used to send qso's to QRZ
Check your QRZ lookup connection works in the settings/program config/info providers menu, clicking the small icon to the right of the password box should result in a green check mark to the left of the QRZ user name (Your call)
Dont forget that sometimes QRZ gets stressed during periods of high activity and today was a big contest so it might be a QRZ issue that will be resolved by tomorrow after the contest
