IC-7760 Filter Always Changes to FLT2
Posted: 16 Feb 2025, 18:48
by N7WRH
Latest release of LOG4OM using Omni-Rig 1.2 radio IC-7760 (new)
When double clicking on a call in the cluster list the radio changes to correct freq but filter always changes to FLT2 when it should remain unchanged (e.g. FLT1).
Wade
Re: IC-7760 Filter Always Changes to FLT2
Posted: 16 Feb 2025, 20:01
If you search this form you will find the question has been asked before and an answer provided
Posted: 20 Feb 2025, 02:25
by KA1LDD
You may have the wrong rig selected for Omnirig. If that doesn't fix it, you may have to go into the .ini file and make some changes. I had to do this for my IC-7700. Its not a big change, but if you don't know what you're doing, it can be confusing. The owner's manual for the 7760 should give you the numbers you need.
Posted: 26 Feb 2025, 17:44
by N7WRH
G4POP wrote: 16 Feb 2025, 20:01 If you search this form you will find the question has been asked before and an answer provided
I found the "previously unposted" solution to be the Hamlib 7760 alpha file
Posted: 26 Feb 2025, 17:56
by N7WRH
KA1LDD wrote: 20 Feb 2025, 02:25 You may have the wrong rig selected for Omnirig. If that doesn't fix it, you may have to go into the .ini file and make some changes. I had to do this for my IC-7700. Its not a big change, but if you don't know what you're doing, it can be confusing. The owner's manual for the 7760 should give you the numbers you need.
Your reply put me on the right track to find out there is now an Alpha version Hamlib file for the 7760 which corrected the problem.
Posted: 27 Apr 2025, 02:25
by KA1LDD
I'm glad I could help. It took me quite a while to figure out how to fix the issue with mine, so I know how frustrating that is when you're not even sure where to look for the answer.
Posted: 27 Apr 2025, 12:36
by KI5IO
Glad that y'all found your solution for the IC rig(s).
Just in case y'all are not aware ... Mike Black - W9MDB became a SK on March 28, 2025.
https://www.qrz.com/db/W9MDB
He was "Mr. Hamlib" ... the lead developer for that APP. I've not seen any general posting about who might pick up where Mike left off. Many OMs worldwide have provided support to Mike, but we will just have to see how Hamlib fares moving forward.
