Uploading to LoTW is seamless but uploading to eQSL is a different story. No matter what I do I see "Error NO MATCH ON APP_EQSL_QTH_NICKNAME: HOME" in the upload confirmation window. I've had the techs at eQSL look on their end and everything appears to be ok. I've tried different Nicknames and that doesn't matter either.
73, Jeff VE3JP
Error uploading to eQSL
Re: Error uploading to eQSL
Dont forget the nickname has to match perfectly and its case sensitive
Well I sort of figured out the problem. Log4OM is only using or seeing the "QTH Nickname" for the primary account in eQSL. I have 3 callsigns with 3 different "QTH Nicknames" in eQSL. Even though Log4OM gives you the area to fill in the QTH Nickname for eQSL, it is only seeing the primary account. I've reached out to eQSL and they have said it is not their issue. If that is true then I am left to assume there is a bug in Log4OM.
Have you linked your call signs in eqsl?
If your operating several different accounts with different calls, passwords and nicknames then you should probably set up a Log4OM configuration for each.
I have two calls and each has a different nickname with eqsl but I dont have an issue probably because although the calls are linked one of the calls is my old call and no longer used in anger
I'm not sure if they are "linked" in eQSL. All I know is that I only have one main password to get into eQSL. From there I can edit the 3 different calls I have. I have seperate "QTH Nicknames" for each. Like I said before, the only way I can get Log4OM to upload to eQSL is to use my primary "QTH Nickname" but that is not the call I want to use in Log4OM. Log4OM is the only one that is giving me grief. I also have "AClog" , "N1MM", and "Ham Radio Deluxe". There are things that I like about Log4OM, but if this can't get figured out I'm gpoing to have to drop it.
Nobody has responded to my last post but just to add, with speaking to eQSL support it appears that for whatever reason Log4OM is only seeing, or choosing to only use the "QTH Nickname" for my "primary" callsign in eQSL. If I use that QTH Nickname, I can upload from Log4OM to eQSL, but, again, that is not the callsign that I want to use in Log4OM. If I use the "QTH Nickname" that corresponds with the casllsign I want to use in Log4OM, it will not upload.
73, Jeff
73, Jeff
I have 11 QTH nicknames in eQSL.cc, and I switch 6 of them between 6 accounts in Log4OM2 without any problems.VE3JP wrote: 05 Mar 2025, 16:28 Nobody has responded to my last post but just to add, with speaking to eQSL support it appears that for whatever reason Log4OM is only seeing, or choosing to only use the "QTH Nickname" for my "primary" callsign in eQSL. If I use that QTH Nickname, I can upload from Log4OM to eQSL, but, again, that is not the callsign that I want to use in Log4OM. If I use the "QTH Nickname" that corresponds with the casllsign I want to use in Log4OM, it will not upload.
73, Jeff
Let's review the settings for your Log4OM2 account.
73, Kiyo JA9HWD
A mi me pasa lo mismo no hay forma de que los qsos pasen en automático a eQSL.cc pero pongo el JTDX y pasan todos, cuando trabajo con log4om y WSJT-X no pasan ninguno, tampoco suben a HRDLOG ni a CLUBLOG, espero resolver este problema un saludo ea4po Jose Luis
