Contest mode not working
DJ1FTI
Post by DJ1FTI »
I am running 2.35.1.0
Contest mode never start.
I set up start and end dates in Contest setting
Clicking on Contest mode or on the crown does not start the mode
Can anybody help me?
Re: Contest mode not working
You do realise we removed the pop up contest window some time ago don't you?
Contest mode now changes ui by adding fields and highlighting green and its working here
DJ1FTI
Post by DJ1FTI »
G4POP wrote: 15 Mar 2025, 19:12 You do realise we removed the pop up contest window some time ago don't you?
good is working for you but it is not activating for me, no extra field noticed
can you help?
post image of the contest set up window please
G0TRT
Post by G0TRT »
Hi Luca,
I was just about to post in agreement, but I found the problem.
Make sure that in contest settings that the start date/time AND finish date/time are set. The finish date doesn't automatically change to the start date like you might expect it to through your experience of other software.
Once I checcked and chaged this contest mode worked.
DJ1FTI
Post by DJ1FTI »
G0TRT wrote: 18 Mar 2025, 04:02 Hi Luca,
I tried during a contest but did not work
now I did faking again same contest and it is working
good so
thank you G0TRT, 73
