In eQSL.cc, when uploading data with a status of "Request" in Log4OM2 using QSL Manager, I would like it to be uploaded unconditionally without duplication checks or other error checks, and error checking to be left to the eQSL.cc server.
I just want to modify the QSLMSG, but even if I change it to "Request" in Log4OM2, the upload does not succeed. This may be because Log4OM2 stops processing when a Dup warning is returned from the eQSL.cc server.
When uploading with ADIF, a Dup error warning and other warnings are displayed from the eQSL.cc server, but the upload is completed successfully. For example, if I want to change QSLMSG, I can change just that. I would like it to be possible to modify it in the same way in Log4OM2.
Re-upload to eQSL.cc
73, Kiyo JA9HWD
Re: Re-upload to eQSL.cc
the dupe message is send by eQSL. Log4OM sends the data if you tell Log4OM to do that (as you did by changing the eqsl sent status to REQUEST) as you expect, but it's eQSL that reports "dupe".
What eQSL does on his side is our of our control. They can update the actual record or refuse the data, in both case Log4OM completes the send successfully.
It's what happens on eQSL side that is out of our control
Understood. Looking at the log, I can see that the update has indeed been performed. Moreover, I was able to confirm that the time when it was written to the eQSL.cc OutBox has also changed.
I posted this thread as a request.
I'll need some time to consider whether to leave it as a request or a bug report.
The reason is that even though I fixed QSLMSG, it hasn't been reflected in eQSL. I didn't think this was a bug, so I haven't made any preparations. I'll wait and see, and if I'm sure it is a bug, I'll resubmit it as an error report.
73, Kiyo JA9HWD
