WSJT Radio Communications
AD4ES
Post by AD4ES »
I am new to LOG4OM and really like what I see. I have watched a lot of videos on WSJT integration and reviewed the manual. I am as confused as ever. I understand the UDP and ports stuff. But I do not find what the RADIO settings should be on WSJT. Is WSJT getting and sending frequency and mode information through LOG4OM 2 or is it getting it to/from the radio? If it is getting frequency and mode information from/to LOG4OM what are the settings? LOG4OM 2 connects just fine to Thetis SDR using TCI interface.
I am using LOG4OM 2 V 2.35.1.0, Thetis SDR V10.3.8, Windows 10, Intel Core i5 with 14 cores, 16GB physical RAM, and TCI interface to LOG4OM 2. WSJT RADIO tab information needs to be set up.
Chuck AD4ES
Re: WSJT Radio Communications
Use MSHV it interfaces with TCI same as Log4OM
AD4ES
Post by AD4ES »
Thank you. I downloaded the software. The software and the manual do not specifically mention TCI interface. Do I use "Simplified UDP Broadcast" and use the computer IP and port? Also, when executing the program the top banner says 70MHz version 2.76.1 64 bit. I do not understand that either!
Chuck AD4ES
You could try reading our user guide re MSHV integration using tci for CAT and spot display on spectrum of Thetis and udp connection for logging
