IC-7300 switchng to FIL2 with WSJT-X
Posted: 25 Mar 2025, 01:55
by W2KYM
Hi everyone!
I'm running Log4OM with Omnirig on my IC-7300. When I use WSJT-X, the filter automatically switches to "FIL2" and does not stay at "FIL1". Now I've isolated WSJT-X from Log4OM and it works like it should. When I start using Log4OM and Omnirig again, it returns to the original stated problem. Any ideas on how to solve this? Suggested most welcome.
73 all
Jim W2KYM
Re: IC-7300 switchng to FIL2 with WSJT-X
Posted: 25 Mar 2025, 09:00
This is a known Omnirig rig ini issue - If you search this forum there is a mod you can do to the ini file
Posted: 25 Mar 2025, 18:39
by W2KYM
Awesome sauce!!!
Thanks Terry :D
Jim W2KYM
Posted: 25 Mar 2025, 19:05
by W2KYM
Well Terry, I'll be damned if I can find it either here or the user manual....
Posted: 25 Mar 2025, 20:39
Not in user manual it's somewhere on this forum, search omnirig filter that should find it
Posted: 26 Mar 2025, 18:44
by W2KYM
G4POP wrote: 25 Mar 2025, 20:39 Not in user manual it's somewhere on this forum, search omnirig filter that should find it
Yep, and I did just that and finally found it. In the IC-7300-DATA .ini file, open notepad as administrator and add the following change under [pmDig_U]:
[pmDig_U]
; These lines select USB-D Data Mode 1 (DATA1 MOD) which defaults to USB sound card modulation,
; FIL1
Command=FEFE98E0.2600.01.01.02.FD
ReplyLength=16
Validate=FEFE98E02600010102FD.FEFEE098FBFD
73 and thanks for all your help!!
Jim W2KYM
