Operator Name not showing
KR4AYE
Post by KR4AYE »
Brand new user, fresh install.
See screenshots, the Operator Name is not showing in the main field or the Name field under Recent QSO's. Seems to not be pulling from Info Providers. All other fields seem to be OK.
I have confirmed Info Providers have correct username and pw's
Running Log4OM version 2.35.1.0 and WSJT-X v2.7.0 on Windows 11 Home v24H2.
Any suggestions for troubleshooting are appreciated.
Screenshot 2025-03-26 143615-2.png (226.82 KiB) Viewed 2415 times
Screenshot 2025-03-26 143452.png (222.79 KiB) Viewed 2415 times
KR4AYE
Re: Operator Name not showing
Firstly whats your call sign??????????????????????????????????????
Secondly did you see a green check mark when you tested the connection?
KR4AYE
Post by KR4AYE »
G4POP wrote: 26 Mar 2025, 19:24 Firstly whats your call sign??????????????????????????????????????
KR4AYE. I just added it to my signature.
Yes. It seems to be working after several restarts of each software. Is there a preferred start order? Log4OM first or WSJT-X first?
KR4AYE
Start order should not make any difference
IU5KYZ
Post by IU5KYZ »
Good morning with the latest update to 2.35.1 I also find myself with the same problem when I confirm the qsos from jtdx it loads them on recent but it doesn't show me the name of the corresponding om 73 iu5kyz
WhatsApp Image 2025-04-23 at 07.59.25.jpeg (231.63 KiB) Viewed 1484 times
When you see this is only the FT8 QSO's and not the SSB ones would it not make you suspect that something is wrong with the WSJT connection, like UDP settings?
IU5KYZ
Post by IU5KYZ »
Thank you very much, problem solved. 73 IU5KYZ Francesco
