Adjusting information boxes
Posted: 10 Aug 2014, 05:55
by KA1NAV
Hi I just downloaded the program and I am having a information box spacing problem. The QSO (f1) information box is cut off at the bottom so only 1/2 of the band the next box and the freq bos can not be accessed. This also happens on Club (F3) and Sat (F6) I have tried to move the bottom box of QSO look up ( Large world map) but it only increases the size of the QSO worked box on top or the DX spot box on right. What can be do about this?
Thank you
Verne
Re: Adjusting information boxes
Posted: 10 Aug 2014, 08:13
This is a known issue discussed several times on this forum.
You have you Windows font size set higher than 100%, change back to the normal setting and all will be OK
We are working on resolving this problem
Posted: 15 Aug 2014, 13:05
by WS2K
I am also interested in this resolution. I use a laptop to log, and having a font size of 125% makes the fields so much more readable. But the boxes are cut off (especially the RST, location, and band/frequency boxes). Adjusting those windows to work with a larger font % would be very helpful for me.
A question for you - is it possible to change the font used on any page? I ask because the cluster bolds the call sign received, which stands out very clear. I was looking for a way to bold everything, or at least change the font type. Is this possible to do, either now or on a future release?
I use this program daily and haven't found anything else out there that even comes close. Keep up the great work!
73-Joe
