Frequency Entering
dl2cc
Frequency Entering
Post by dl2cc »
I would like to suggest being able to enter a frequency in khZ in the callsign field or in the frequency field.
The up/down 1 digit concept of individual digits in the frequency display is kind of hard to use when jumping from one band to the other.
In addition a band/mode selector would be great to be able to click on a band/mode.
Re: Frequency Entering
Why when you can hover your cursor over the freq display characters and use mouse wheel to change htz, khz, mhz?
You also have a CAT control screen and direct entry in input UI
dl2cc
Post by dl2cc »
I found the CAT screen now,
thanks.
What do you mean by "direct entry in input UI"?
dl2cc wrote: 08 Apr 2025, 16:36 I found the CAT screen now,
thanks.
without CAT you can enter the freq in the main input UI under the country and zone info
