WSJT-X Connection Issues
KI1U
Post by KI1U »
I'm hoping someone has experienced this issue and can assist.
Today the logging connection between WSJT-X and Log4OM2 stopped working. The window to log the QSO would pop up, I hit OK, and nothing shows up in the log. Double checked the UDP connection, no changes there. I tried resetting the UDP connection per the manual. When I did that it also prompted me to enter all my station data, which I had already entered some time ago. Still no luck with the logging connection. I am not getting an error message. Tried refreshing the log and new QSOs are still not showing up.
Shortly after this I noticed this another problem popped up, Log4OM started changing FT8 to RTTY in the mode field. I recall this happening before, but can't remember what the fix was.
Everything with OmniRig looks good, nothing has changed with the rig (IC-7610). WSJT and Log4OM2 are both running the latest versions.
Any help would be appreciated.
Mike, KI1U
