Changing email address
Posted: 15 May 2025, 16:57
by G4NUO
Can someone advise how I can change my email address which is logged with Log4OM. The email address I registered against my call sign is no longer usable and somehow I can't change it. New installs of L4OM continues to display the invalid address even after uninstall and deletion of Appdata in Windows User folders? Am I correct also that some data related to callsign is stored in folders which are not on my host PC?
Re: Changing email address
Posted: 15 May 2025, 17:13
Please DO NOT delete the AppData folder or its contents it will affect other programs, not just Log4OM
Posted: 15 May 2025, 17:16
Now I have your attention where do you see the email address in Log4OM and what part of log4om does it relate to?
Posted: 15 May 2025, 18:00
by G4NUO
No I have only deleted the entries related to Log4OM not the entire folder.
It is in the configuration settings. Program Settings --> Email settings. The address is somewhere central and is an old one picked from somewhere. I would have thought I could change it locally.
Posted: 15 May 2025, 18:02
You should be able to change it in the program config
It's stored locally
BTW I was able to update my email address in Program Config
Posted: 15 May 2025, 19:03
by G4NUO
Thanks Terry. I think I've sorted it. Greyed out because email wasn't active
Posted: 15 May 2025, 19:32
G4NUO wrote: 15 May 2025, 19:03 Thanks Terry. I think I've sorted it. Greyed out because email wasn't active
That would do it!
