I've looked around and didn't see a reference, so I'll ask and if there's someone who knows of a past thread, I'll be happy to review.
I'd like to know if there's a way to filter awards by specific mode. For instance, WAS has a digital filter, but there are endorsements for each specific mode (JT65, PSK31, RTTY, etc) and was wondering if there was a way to track progress towards these endorsements?
Or, do I need to set up my own award to get this information?
Thanks & 73,
Jim, WD9HBC
Filter awards by mode
Moderator: OE6CLD
Re: Filter awards by mode
I have the same question. Is there a way to break out individual digital mode awards?
WD9HBC wrote: 16 Jan 2017, 16:00 I've looked around and didn't see a reference, so I'll ask and if there's someone who knows of a past thread, I'll be happy to review.
Thanks & 73,
Jim, WD9HBC
Currently Log4OM only tracks AWARDS, not endorsements.
The only way you could do that at this time is to:
Use the QSO Archive manager to select just QSO's for the mode of interest i.e. PSK by using the 'Search Parameters' facility
Export those QSO's to an ADIF file
Create a new database (File/New Database)
Import the ADIF file to the new (Empty) database
Use Statistics and awards for the analysis of those QSO's
Revert to original database for normal operations
Its a rather long and ponderous way of doing it but it would provide what you require and the only method currently available
Correct Terry.
i'm checking if it's easy and fast to add another filter.
Probably yes
Probably yes
Hi Daniele,
It was also my intention ask for this, but as you are working on V2 I have not asked, but now I say Excellent if possible, it would be great.
73 Manuel Fernando CT1BXX
added for WAS. Obviously other filters should not be in contrast... so if you ask for DIGITAL award and you filter for SSB no results will be displayed)
Added also a MODE category filter for locator statistics
Will be available soon after beta testing, started today
Hi Daniele,IW3HMH wrote: 30 Mar 2017, 10:09 Correct Terry.
Probably yes
If you permit...
It would be great within User_Awards select the mode we want to track.
I would like to have possibility to create a view for 60Meters for FT8 only.
If we can select a mode we want, we can create several views...
