Page 2 of 3
Re: LOG4OM V2 & JTDX problem.
Posted: 16 Jan 2020, 17:59
F1NQP wrote: 16 Jan 2020, 17:56
It doesn't work through FLDIGI either.
I'm going back to the V1 until better days come.
I did not say through Fldigi I said to use the same method of adif monitoring.
It works 100% for me so not sure what your doing wrong?
Posted: 16 Jan 2020, 20:03
by F1NQP
I don't use OMNIRIG.
I have 2 TRX, one ic-7610 for the decametric part, and one IC-9700 for the V/U & SHf, connected directly to the PC by 2 simple USB cables.
With JTDX, I open 2 simultaneous sessions to monitor 2 bands. The advantage of the V2 is that it manages 2 (or more) UDP ports. Until now I was in automatic logging in deca or I do more qso, and I was manually entering the V/U qso.
So I'm going to wait for a TCP port implementation, so that LOG4OM2 works with JTDX.
Thanks again for your work.
73 to all and good evening.
Translated with
www.DeepL.com/Translator (free version)
Posted: 16 Jan 2020, 21:34
by gi4fue
***TEMPORARY WORKAROUND
***However I was able to log from JTDX to Log4OM V2 by using our ADIF inbound function, read the user guide about FLDigi ADIF use the same ***principle but direct path to the JTDX folder in AppData
I am also thinking that this will work for DM780
Time to experiment
Charlie GI4FUE
Posted: 16 Jan 2020, 21:38
Charlie
I think HRD still use an mdb or Maria database not an ADIF
btw John GI0HWO has been try to reach you for help with aerials
HNY mate
Posted: 16 Jan 2020, 21:53
by gi4fue
Hi Terry
Have spoken with John on FB, we will sort something for him when the WX improves. I presume the V1 method of logging DM780 will not work with V2 using UDP Inbound..didnt work for me...I know Fldigi works, I just dont like it!!
73 es HNY - Charlie GI4FUE
Posted: 16 Jan 2020, 21:57
No Charlie dear Rick Rhule of HRD LLC crippled the service because we fell out
Posted: 16 Jan 2020, 21:59
by gi4fue
Hi Terry
Cancel that last atatement...V2 Does work with DM780 using UDP..Mini deluxe, HRD Log and DM780
73, Charlie
Posted: 16 Jan 2020, 22:02
by gi4fue
Hi Terry
I'm using the last free version of HRD
Posted: 16 Jan 2020, 22:05
gi4fue wrote: 16 Jan 2020, 22:02
Hi Terry
That's why it works he screwed version 6 onward
Posted: 16 Jan 2020, 22:14
by gi4fue
I forgot to mention that I have JTAlert v 2.14.4 logging to V2. I set the UDP port in JTDX to 7851 and this seems to work although JTAlert tells me the QSO is not logged, It actually does log to V2. In V2 i have UDP inbound ADIF messages set on ports 2236 and 2237, I presume its using 2237 as this is the WSJTX default and its the same structure in JTDX
Hope this is of use
73, Charlie
