OMNIRIG and IC 7300 HELP
TEX
Re: OMNIRIG and IC 7300 HELP
Post by TEX » 29 Sep 2016, 23:23
K7PT wrote:Hi Tex,
We would greatly appreciate to know your call sign. Please! :?:
Sorry Its VK1TX
TEX
Post by TEX » 29 Sep 2016, 23:27
I think you Hit the nail on the head!
That's what I did eh!
I will try to uninstall all the Icom drivers and also reinstall OMNIRIG and see what happens.
Also just a point still cannot see IC-7300 on the cat listing in the Log4OM software.
regards,
TEX
ps thanks for the nice videos on Utube.
Post by G4POP » 30 Sep 2016, 11:10
TEX wrote:Hi Terry,
regards,
TEX
Tex
Make sure that you uninstall Omnirig to ensure that the latest ini files are installed with the new version of Omnirig - Don't use an existing download of Omnirig, download a new version
F1VEV
OMNIRIG and IC 7300 Help
Post by F1VEV » 15 Oct 2016, 13:40
Hi Terry
Got all working nicely but still getting used to new program also got it to work with WSJT and JT alert 90% of my work.
Have the 7300 file for omnirig but it is far from stable when on WSJT the QRG and or mode jumps and CAT is lost need reset WSJT, a bit annoying when in middile of QSO
Could not find Omniri forum any pointer would be welcomed
73 Jacques
Icom 7300- Dipoles
BY-1 Bencher - KT-1 keys
PCIntel i3 3.3GHZ - 16GB Ram - 1To external backup - QL700
PC: Win 10 Pro X64 - MS Office. Avast. NTP 4.2.8
Log4OM - N1MM - MTTY - WSJT-X 1.6.0 - JTAlert 2.8.4
Memberships: REF - ARRL.
F1VEV
Post by F1VEV » 16 Oct 2016, 07:18
Upon further investigation- observation I noted the following:
If doing QSO while doing changes to Log4OM TX was erratic if left the set up run and made no changes to Log4OM the it was stable ...
strange behaviour ?
Icom 7300- Dipoles
Post by G4POP » 16 Oct 2016, 08:13
RF in the shack maybe?
I was just working some stations and was logging at the same time without issue so it's not the software!
F1VEV
Post by F1VEV » 16 Oct 2016, 09:14
Hi Terry
No RF in shack this morning stable until I went to 20M from 40M erractic and even when reverted back to 40M on JT65
out of interest went back to HRD RIg Control can move all bands an stable . wonder if Rig control HRD can work with your software
anyway have a good week end Jacques
Icom 7300- Dipoles
Post by G4POP » 16 Oct 2016, 09:23
No and it never will Jacques!
Same Radio, cable and computer with HRD?
F1VEV
Post by F1VEV » 16 Oct 2016, 09:39
I thought as much anyway set up is absolutely all identical in all aspects
Just have to change the WSJT radio settings from Omnirig Rig 1 to HRD that is all that is changed power out 20W same etc etc .
BTW no RF in shack .
So currently using Rig control Jt alert logging to Log4OM works fine if not ideal .
Icom 7300- Dipoles
