Omnirig CAT trouble, Mode=changing, Freq=not changing
PE5TT
Post by PE5TT »
I am new to Log4OM but i have some issues with the CAT control.
When i start the program and click on a callsign from a cluster spot the radio is tuned to the correct frequency and mode is set accordingly.
But after some time the frequency is not changing anymore. however the mode is still switching according to the cluster spot.
Only way to solve this is to close Log4OM and restart it. Then it works oke for another some minutes.
As a test is also started the Omni-Rig client program parallel to Log4OM.
With this Omnirig client i am still able to change the frequency when it is not possible anymore from within Log4OM, strange thing is that Log4OM is still tracking these frequency changes.
Also when i turn the dail on the transceiver Log4OM is tracking these frequency changes perfect. But it is not possible to change the frequency from within Log4OM.
The CAT Status icon in the lower left side remains green.
*********** LOGGING LEVEL: TRACE MODE *******************
2016-01-17 16:32:56.1988 TRACE: #xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx: SET: CAT mode requested for 21078,0 is USB DIGITAL
2016-01-17 16:32:56.1988 TRACE: OmniRigManagement: CAT LOG4OM -> OMNIRIG MESSAGE: Set MODE to: PM_DIG_U on rig 1
2016-01-17 16:32:56.2038 WARN: OmniRigManagement: OmniRigEngine is not initialized
2016-01-17 16:32:56.5438 DEBUG: OmniRigManagement: CAT OMNIRIG -> LOG4OM MESSAGE FROM RIG1 PM_VFOAA FREQUENCY: VfoA= 21065 / VfoB= 14075,88 / VfoUndefined= 0 / RX= VfoA / TX= VfoA
2016-01-17 16:32:56.5488 TRACE: OmniRigManagement: CAT OMNIRIG -> LOG4OM RIG1 PM_VFOAA Rig1Freq: 21065000 Rig1RX: 21065000 Rig1TX: 21065000 Rig1.FreqA: 21065000 Rig1.FreqB: 14075880 Rig1.SPLIT: PM_SPLITOFF
2016-01-17 16:32:56.5513 DEBUG: OmniRigSinkClass: CAT OMNIRIG -> LOG4OM MESSAGE FROM RIG1 MODE PM_DIG_U SSB
2016-01-17 16:32:56.5513 DEBUG: TCPServer: TCP MESSAGE OUT: RigStatusMessage CAT FREQTX B:False D:21065 S: --- FREQ B:False D:21065 S: --- BAND B:False D:0 S:15m --- MODE B:False D:0 S:PM_DIG_U --- MODEFORLOG B:False D:0 S:SSB --- CATCONNECTED B:True D:0 S: ---
2016-01-17 16:32:56.5538 TRACE: OmniRigManagement: CAT OMNIRIG -> LOG4OM MESSAGE - Informations: 21065 21065 PM_DIG_U SSB
Kenwood TS590sg
Windows-7 64bit
Omni-Rig 1.16
Log4OM 1.24.0.0
** EDIT: Changed the topic title since it seems to affect not only the Kenwood TS590 **
w8otr
Re: Kenwood TS590SG, Omnirig CAT trouble
Post by w8otr »
I have had that happen also ! windows 7 and windows 10 with Omnirig
NN7D
Post by NN7D »
I have had this issue since maybe v1.22, after Daniele made some changes to how Log4OM works with OmniRig. At that time it seemed like I was the only one with this issue, but now others are reporting it. The key here is that after some time, when clicking on a spot in Log4OM, the mode will change, but not the frequency. And yes, another OmniRig client, like BandMaster will continue to work via Omnirig to change the mode AND frequency on the rig.
Here is a workaround to get CAT back working fully in Log4OM. Click the headphone icon tool bar button to bring up the OmniRig interface window, change the port to some other port not used, click OK, then open up OmniRig again, change the port back to the correct port and click OK. Full CAT operation should return.
Windows 7 - 64 bit, IC-7600.
Doug - W7DRM
KG8V
Post by KG8V »
I too have had the same problem. ver 1.24, windows XP and Icom 7600. Mode changes but Freq does not.
tnx, Robin, KG8V
oe4hds
Re: Omnirig CAT trouble, Mode=changing, Freq=not changing
Post by oe4hds »
I just discovered the same problem.
Whenever I go into the settings and exit the settings window, the issue apears. When I open the omnirig interface and confirm by clicking ok, everything works again.
oe4hds
Post by oe4hds »
You don't even have to commit the omnirg window. Only open it and close it.
So to get the problem, just open the settup windo and close it.
To get it working again, open the omnirig window and close it.
100% reproducable here with my TS590S.
PE5TT
Post by PE5TT »
Yes, oe4hds you are 100% right, :D
The problem occurs after entring settings screen. (since i am new to Log4OM, i enter settings a lot).
After that frequency is not changing anymore. But opening the CAT control by pressing the "headset icon" en clicking the "Ok" button in the Omnirig window seems to re-initialize the CAT connection and after that it works oke again.
N4RF
Post by N4RF »
I am having Omni Rig problems also. Almost everytime I turn on my ICOM 7600, CAT is not working. I have to change from COM8 to COM9 and then back to COM8 and then it works.
Sometimes it works when I power up the 7600, but most of the time it won't. It is not a consistent problem. Perhaps 80% of the time I must change COM ports and then return to my normal COM8 for CAT to work. It continues working properly until I turn off the transceiver. It is a bit irritating, hi.
Bob WU6C
WU6C Bob wrote:I am having Omni Rig problems also. Almost everytime I turn on my ICOM 7600, CAT is not working. I have to change from COM8 to COM9 and then back to COM8 and then it works.
Bob WU6C
I would surmise that you are using the dreaded USB connection for CAT instead of the ACC connection, if so it sounds like either the USB drivers are not installed correctly - Uninstall the driver, do a fresh download from Icom JP and reinstall
Or perhaps you may have the same issues that other 7600 owners have encountered of a faulty USB port on the rig - See the 7600 Yahoo Group and Facebook site.
I am fortunate that my 7600 works fine with either the USB or ACC, CAT connection
LA9FFA
Post by LA9FFA »
oe4hds wrote:I just discovered the same problem.
Its the same problem here if I go to settings then opitons then click ok or exit the option window the problem apears. opening omnirig and click ok does NOT resolves the problem in my case. I have to restart log4om.
I use Icom Pro III, Omnirig,VSP and Windows 10 Pro.
Never had any issues before.
