Log4Om 1.26.0 Released
All relevant news related to Log4OM software will be published here.
Post by IW3HMH » 19 Aug 2016, 16:44
Release 1.26 of Log4OM is a maintenance release to fix the following issues
- Grid reference were not being updated when call edited - Reverted to locator update on new lookup and added a lock button to the locator field for manual input
- RST set in Net control not saved correctly - Changed format and now an active call in a net should be highlighted to update the RST from the default set
- Added a control to prevent Net Control form closing with an active NET - Now warns on closing a net that there are unsaved calls in the active window.
- Upload LOTW button now visible in Italian language version
- Notes field now not cleared when adding a QSO
- After sending spot, focus stays on spot "globe", pressing enter opens another spot - Fixed
- Added some log optimizations to cluster calls
- Code optimizations on cluster connection, database and statistics
- Improvements and new application logs added on the software base code
