Yet another idea for v2
G4DWV
Post by G4DWV »
My suggestion is that Log4OM would remember its size and internal panel arrangement between sessions. Currently, I have to go though this each time I load Log4OM.
Whilst checking to see if the current release had anything that would appear useful. I noticed a "Reset Form Positions" button at the bottom of each config panel. I searched for this exact term but did not get any hits in the manual. What does this button do?
Tnx es 73 de Guy G4DWV 4X1LT
Re: Yet another idea for v2
Resets the forms to default - No data in the options tabs
G4DWV
Post by G4DWV »
Thanks Terry.
Another question springs to mind. Is it possible to get rid of the "confirm exit" warning?
Cheers
Guy
G4DWV - Guy wrote: 03 Jun 2017, 14:35 Is it possible to get rid of the "confirm exit" warning?
No it is not
G4DWV
Post by G4DWV »
I'd like to request that this option is included in v2 if possible.
Guy.
Confirm exit was added some years ago at the request of many users to avoid accidentally closing the software while in QSO so I don't think we will revert unless we get a large number of requests from users to remove it
I have a few APPs that allow an on/off tick selection where the close prompt is then chosen by the user.
G4DWV
Post by G4DWV »
Hi Nolan,
My thoughts exactly. It is all about choice.
wb5yes
Post by wb5yes »
I would like to add another request for the option to disable the "Confirm exit?" dialog. I use JTAlertX to start and stop wsjt-x and Log4OM, so it would be nice to have everything close when I close JTAlertX. As it is, everything closes except Log4OM and I have to manually confirm that every time.
Thanks,
Howard - wb5yes
G4DWV
Post by G4DWV »
Howard,
Please see Terry's response to this request. Personally, I'm with you on this one for the same reason, but appartently we are in the minority :cry: .
73 de Guy
