Log4om 1.31.0.0 database issue
pa3djy
Re: Log4om 1.31.0.0 database issue
Post by pa3djy »
Hello friends,
The same here. I have 38.000 records that Log4OM 1.3.0 loads in about 10 seconds (fast enough for me.
I installed 1.3.1 today and had the same problems, it took more than 2 minutes to load all and
after a few moments i experienced a black screen with a green border. Had to quit the program
with the Taskmanager. I got my old version 1.3.0 back and runnning.
This is no actual complaint because i know how hard it is to run a "free", for itself excellent, program.
Maybe more a point of attention.
Gerrit de PA3DJY
As stated in previous posts in this thread 1.31 had a bug you need to install 1.31.10
VK7XX
Post by VK7XX »
IW3HMH wrote: 28 Jan 2018, 20:35 I'm investigating the issue. Expect a fix soon. I'm sorry, beta testing didn't revealed that glitch.
thank you for lookig in to this Lele and for the rapid response of the 1.31.1.0 release which is working very nicely :-)
regards
John
VK7XX
pa3djy
Post by pa3djy »
I am sorry Terry,
I installed the latest fixed version 1.31.1 but nothing has been changed.
The loading time of my log was about 10 sec. Now it takes more than 2 minutes.
I am back to 1.30.
73;s
Gerrit PA3DJY
hfsparks wrote: 29 Jan 2018, 19:53 I am sorry Terry,
I am back to 1.30.
73;s
Gerrit PA3DJY
Are you certain that you installed this version http://www.log4om.com/dl/#
And that you installed it to RUN AS AN ADMINISTRATOR by right clicking the install file and selecting "Run as an administrator"
VK7XX
Post by VK7XX »
G4POP wrote: 29 Jan 2018, 20:01
I am back to 1.30.
73;s
Gerrit PA3DJY
I agree with Terry. Something not right with your 1.31.1.0 installation. 1.30.0.0 took 35 seconds to load my 69290 contacts... 1.31.0.0 took 4 minutes and 1.31.1.0 takes 20 seconds neat.
John
pa3djy
Post by pa3djy »
Hello Terry,
I downloaded the latest 1.31.1 version and installed it with administrator rights.
The program starts as normal (even quicker) but i lost a great deal of my qso's in the log.
The latest log entrance showed is 11-10-2017 while i made some few hundreds of qso's
after that date. The version shows 1.31.1. When i close the program and restart it, the old version
comes back 1.30, i got a warning that a new version is available and i have my log till today back.
I looked for an answer in my firewall, i switched it off. When i install the 1.31.1 again the installation
sequence runs smootly but the program halted into a black screen with a green border.
Any suggestions?
By the way i run Windows 8.1
Gerrit
VK7XX
Post by VK7XX »
hfsparks wrote: 31 Jan 2018, 20:15 Hello Terry,
Any suggestions?
Gerrit
"black screen with a green border." by any chance are you running a sandbox style anti-virus like Comodo ?? when Comodo isolates a program, it puts a green border around the program's window.
John
pa3djy
Post by pa3djy »
Hi John,
Yes i am running a Comodo firewall.
But i have checked that, i even disabled the firewall.
73's
Gerrit
Hi Gerrit,
that´s very special that you´ve installed 1.31.1 but after restart 1.31 will be there.
Try the following:
Locate your backup folder and save the latest working backup to another folder.
Do the same with the latest ADIF backup which have all your qso´s in (it´s in the same folder).
Uninstall Log4OM complete.
Delete all Log4OM folders include the folder in C://user/your user name/appdata/roaming/
Download and run CCcleaner and let it do a Registry cleanup.
Restart the PC.
Download a fresh installation file of Log4OM V 1.31.1 and install it with administrator privileges.
Unpack the latest Backup in the config folder (see above).
Start Log4OM, create a new database and make it active (don´t forget to save).
Restart Log4OM and import the latest full ADIF into the empty database.
Hope that helps ... ;) ;)
